Inserito il - 15 ott 2007 : 19:51:24
Qualcuno ha la legenda che permette di interpretare i codici dei motori GM, cioè cosa vuol dire Z, 20, L E T per esempio. Io ce l'avevo, ma non la trovo più nel mio HD, cazzarolla! borgiaz
Città: Trento
2423 Messaggi |
Inserito il - 15 ott 2007 : 22:49:39
Vauxhall/Opel engine identification conventions All engines manufactured by Vauxhall/Opel - as with those of all vehicle manufacturers - have identification codes, which reveal information about a particular engine. For clarity, an example of a Vauxhall/Opel engine identification code is 'C20LET'. See that engine's node for explanation of the engine and how the designation relates to its specification.
The standard form of such an identification number (for petrol engines, as opposed to diesel engines) is as follows:
ABBCCDE
Where:
A = Exhaust emission standard ahered to by the engine in question (in this case, they are European Community directives pertaining to emission limits). One of the following: 'C' = EC 91/441/EEC 'X' = EC 91/441/EEC (stage 2) Where there is no letter, the engine adheres to EC directive ECE R 83 A.
B = Engine capacity in cubic centimetres (cc). This is a two digit number - e.g. '20' means 2.0 litres, '35' means 3.5 litres.
C = Compression Ratio. One of the following: 'G' = less than or equal to 8.5:1 'L' = 8.5:1 to 9.0:1 'N' = 9.0:1 to 9.5:1 'S' = 9.5:1 to 10.0:1 'X' = 10.0:1 to 11.5:1 'Y' = more than or equal to 11.5:1
D = Mixture system. One of the following: 'E' = Multi-point fuel injection 'Z' = Central injection 'V' = Carburettor
E = Specific vehicle version. This is often not used, and little information exists on the meaning of all the variants of this segment of the code. Some of them are: 'H' = High output/supercharging 'V' = Volume model 'R' = Increased output 'T' = Turbo
As an example, one of Vauxhall/Opel's recent engines, the X25XE (going through the identification in part order):
X - adheres to EC emission directive EC 91/441/EEC (stage 2) 25 - has a 2.5 litre capacity X - has a compression ratio of 10.0:1 to 11.5:1 E - has multi-point fuel injection.
In addition to this, if one were to search out the engine number of the particular engine (as found stamped on the engine block, usually in front of the clutch housing), one would likely find an extended version of the code as described above, with further details in the form:
ABBCCDEFFGGGGG
ABBCCDE are as described above. FF = Country of manufacture. One of the following: '01' = Rüesselsheim '02' = Bochum '08' = Ellesmere Port '14' = Kaiserslautern '19' = Aspern '20' = Hungary '25' = Holden '31' = Brazil '0S' = Szentgotthard
GGGGG is the engine serial number.
In poche parole il codice Z20LET indica: Conforme alle ultime direttice CEE (credo Euro4): Z 2000 CC : 20 Rapporto di compressione tra 8,5 e 9:1 : L Iniezione Multipoint: E Turrrrbo: T
Modificato da - wirestriker in data 15 ott 2007 22:59:00 |
Inserito il - 15 ott 2007 : 23:23:09
Grazz Mattheo! E' tutta la sera che cerco di ritrovare il sito o il forum dove l'avevo leto ma niente :) in compenso ho trovato un sacco di cose folli su questo motore. Volevo verificare se era lo stesso dell'Europa S: credo cambi solo la mappa. Ciao Daniele |
Inserito il - 16 ott 2007 : 11:31:07
Ne consegue che il mio motore ideale è Z20YEH ! b. |
